Forums >> Revit Building >> Technical Support >> wall recess problem
Mon, Sep 11, 2006 at 12:34:24 PM | wall recess problem
ishpalsingh
i created a wall type with 9" brick core and 0.5" th plaster on both sides i.e total 10" thick wall when i created a niche family from a generic wall based family by cut geometry with void tool and inserted into that 10" wall, the plaster layer does not wrap itself on the cut in plan and section i checked with wrap at ends and wrap at inserts both i am confused plz help
Mon, Sep 11, 2006 at 12:35:20 PM | RE: wall recess problem
ishpalsingh
section
Mon, Sep 11, 2006 at 5:27:08 PM | RE: wall recess problem
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Wrap at inserts only works on inserts that use an opening rather than a void... Best bet would be to model the finishes parametrically within the niche family.
Mon, Sep 11, 2006 at 9:11:08 PM | RE: wall recess problem
ishpalsingh
did u mean over the column also that means i have to model it in columnfamily but how will u remove the joint line? as it won't do with joint geometry also when i click save while working in a file revit creates 2-3 backup file at the same place is there any setting where i can reduce the number Post edited on 2006-09-11 21:21:24
Tue, Sep 12, 2006 at 12:18:09 AM | RE: wall recess problem
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
That's correct join geometry will not work in this circumstance. You'd either have to put up with it or model small bits of plasterboard wall separately, as well as a plasterboard floors... Will be a nightmare to change though. I'd put up with the lines and use the linework tool to remove them where they are an issue. HTH.
Regards,
Chris.
Wall Cleanup Problem
Thu, Dec 4, 2008 at 5:39:14 AM
recess in Curved Wall
Wed, Jan 19, 2011 at 4:10:03 PM
How to Show a Recess of an Embed Plate
Wed, Mar 25, 2015 at 2:25:55 PM
How to creat n angle recess wall opening for a window
Tue, Jul 15, 2014 at 5:44:23 AM
how do i recess windows into a wall
Mon, Dec 12, 2011 at 12:52:20 PM
Page generation time: 0.8716
