Forums >> Revit Building >> Technical Support >> Tag problem
Sun, Sep 10, 2006 at 10:58:26 PM | Tag problem
anth
I am working on a tag to indicate the area of a green area, as the green area is not enclosed by wall, I can`t use room tag or area tag. Does anyone know how can i make a tag which can tag to a floor and showing the area of it? thanks
Mon, Sep 11, 2006 at 1:34:35 AM | RE: Tag problem
johann
Hi, You could use your room separation tool to draw the boundary of the green area. This will give the Room tag a boundary to calculate. If the Room Separation Lines need to be invisible you can then turn the Room Separation lines off in the visibility settings.
Wed, Sep 13, 2006 at 3:47:54 AM | RE: Tag problem
anth
Thank you very much~I can make it now
Help. Room Tag Problem
Wed, Nov 28, 2007 at 8:09:48 AM
Problem with Multi Category tag
Mon, Apr 3, 2006 at 12:48:41 AM
Tag Display problem [ 1 2 ]
Wed, Jun 24, 2015 at 9:13:35 AM
15
Keynote Tag defaulting to Category Tag
Fri, Jul 20, 2018 at 11:20:17 AM
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Page generation time: 7.0680
