12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> multi level walkthoughs
whats the eaist way to do a multilevel walkthough?
you can do it as one walkthrough if you want, you will need to adjust height and angle of each camera point.
you could also make a few short walkthroughs and put them together using "movie make" or similar...
so if i went the movie maker route would that be eaiser
it's really up to you...
you might find rendering smaller portions and putting them together with some fading in and out in movie maker a little easier than trying to define a whole path going up and down...
ya it iwould be easier and proly wont take as long rendering. one walkthough i did took 17 hrs. on low quailty.
I have a 600 frame walkthrough that I am getting ready to start and it needs to be done on high at least because it's for a presentation. I'm looking at a week's worth of work.
Not sure what you mean. I did a walk thru of a parking garage where I set the path to go up the ramp just like a car would.
Multi Level 3d into Single Level 3d |
Thu, Jun 18, 2009 at 2:02:02 PM
Multi-level buildings |
Tue, Feb 17, 2009 at 2:27:04 PM
Editing Multi-Level Building |
Wed, Jul 20, 2011 at 11:11:04 AM
Walk through's on multi levels |
Mon, Oct 3, 2011 at 10:32:00 AM
Revit Architecture 2008 Multi Level Stairs - Complex Building |
Sun, Dec 4, 2011 at 4:39:37 AM
