Forums >> Revit Building >> Technical Support >> Turning off certain elements in Visiblity Graphics (VG)
Fri, Sep 8, 2006 at 5:34:05 PM | Turning off certain elements in Visiblity Graphics (VG)
pookie
Heya, is there a way off turning off only certain walls in the model. For example, I've got this very complex building and want to shows certain walls and not others. Is there a way of achieving this? Maybe VG or some other way?
Fri, Sep 8, 2006 at 7:26:27 PM | RE: Turning off certain elements in Visiblity Graphics (VG)
puzzle
4 Stars: 10 Votes
If you are using Revit 9, then you can apply a filter to the walls that you don't want to see. If not maybe use phases.
Macca
Sunshine Coast
QLD Australia
Sat, Sep 9, 2006 at 6:12:07 AM | RE: Turning off certain elements in Visiblity Graphics (VG)
coreed
coreed Avatar
4 Stars: 16 Votes
this little exercise from the Revit Beginners blog will show you how to isloate walls by applying filters http://revitbeginners.blogspot.com/2006/07/stepped-foundation-plans.html HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
draw order
Tue, Aug 19, 2008 at 10:39:46 AM
Turning off one object in all views with one step?
Thu, Mar 27, 2008 at 4:58:50 PM
Walls and patterns showing through objects
Thu, May 24, 2012 at 7:52:20 AM
Help turning off Familys
Thu, Sep 20, 2007 at 12:53:11 AM
mysterious hole in wall
Tue, Feb 5, 2008 at 3:26:44 PM
Page generation time: 3.0867
