Forums >> Revit Building >> Technical Support >> Split surface & paint vs. schedule
Mon, Oct 11, 2004 at 12:48:30 AM | Split surface & paint vs. schedule
ale02
ale02 Avatar
3 Stars: 3 Votes
Hi, again. Has anybody experience this, when we use split surface & paint function, it doesn't reflex the material changed via paint in the schedule? Example in Wall, I have tried using split surface & paint to change the wall material but in the wall schedule (my case, in wall area), it didn't show the differences and it still shows the total area for generic wall. In order to show the different in area, we must split the wall & duplicate the wall & specify them correctly by edit structure & then join geometry again.. This way will be a lot of work if we have a lot of different finishes at different levels or even shapes!! Anyway to get aound this?!
Mon, Oct 11, 2004 at 5:51:59 PM | RE: Split surface & paint vs. schedule
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
As far as i'm aware the paint tool is only for cosmetic purposes and i don't think it can be scheduled as it doesn't physically change the properties of the wall structure... Sorry. Not much help. Maybe in 7...
Tue, Oct 12, 2004 at 3:34:32 AM | RE: Split surface & paint vs. schedule
DIMITRIS
CHECK THE NEW DOCS ABOUT REVIT 7, maybe you find something usefull http://taylor-tech.com/software/getSoftwareByID/16/view.html
split surface hides surface aligned component families
Wed, Jul 31, 2019 at 7:37:57 AM
painting split walls with windows
Thu, Nov 15, 2012 at 3:17:04 PM
Split Facing and Painting both sides of a wall?
Fri, Jan 13, 2017 at 10:52:50 PM
Disappearing schedule items
Tue, Oct 11, 2011 at 1:06:55 PM
Split face and paint on a wall sweep
Fri, Feb 19, 2010 at 4:17:42 PM
Page generation time: 0.2849
