20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Creating Schemes/Layouts
7 Posts No Rating |
Lets say you wanted to show a client 3 different furniture layouts in a banquet hall. How would you do this so that you could have 3 schemes at the same time? As it is now, if you create a new view of an area, and add components, those components also show up in related views. Basically is there a way to have one view and then turn different layouts of furniture on and off???
Phases should work but there may be better ways.
I use phases to keep presentation items off my working drawings.
you could do it with phases but it would be better using the design option.
if you can't see the design option bar on the top, just right click on an empty space on the top bar and choose design option from the list...
remember F1 is your best friend
Design options are great. Under your tools pulldown, create a new design option set and however many options you need to show your client. Then take your furniture plan view and duplicate it for however many options you need. Then for each view, go to your view properties and you should have a new tab called design options, set each view to a different design option. Then you simply edit your options and place your furniture. I find that its easiest to set up the options and the views before I start actually editing options. Then each option has a dedicated view. You can then drag each of those views to your sheet and print them out. A couple of our clients have really appreciated being able to see multiple options all on one sheet.
Ruth Rau Main Street Architecture, P.C. |
Floor/Wall tile layouts |
Fri, Oct 7, 2005 at 2:17:29 AM
area color schemes |
Fri, Jan 27, 2012 at 12:07:13 PM
Revit Spot Elevations, Rooms and Color Schemes Problem |
Mon, Jun 24, 2013 at 12:46:35 PM
Titlle blocks and drawing/detail border layouts. |
Fri, Sep 15, 2006 at 12:25:56 PM
Imported PointCab Layouts |
Wed, Jun 22, 2016 at 5:57:07 AM
