22 Users Online (20 Members):
Forums >> Community >> The Studio >> Underlay Properties
On a roof level, I have the second floor as underlay. However, my doors, bath fixtures, etc don't show up. Just walls. Is there a way to turn these on? I don't see anything in vv.
Thanks.
not that i'm aware off... if you find a way, let me know
Check your 2nd floor view properties. I find that sometimes I turn things off in one view and then wonder why they don't show up when I use it as an underlay. You might also try making your roof view wireframe, sometimes the roof itself blocks the view of anything underneath. Other than that, I'd go into your roof view properties and turn on all the model categories.
That's all I can think of.
Ruth Rau Main Street Architecture, P.C. |
Well now, maybe I found something to post in the wishlist section! I'm glad I'm not the only one. I'll keep looking for the solution. I'm sure I'll stumble upon it sometime. Thanks for the feedback.
I have a residential project with a roof plan with a second floor plan underlay. I couldn't get the door swings to display, but the Visibility settings on the roof plan properties got the walls, plumbing, and locations of doors and windows to display.
To get the door swings to show, I changed the View Range properties in my roof plan. I lowered the "cut plane" to cut at a height that would intersect my doors. If you don't mind "graying" out the roof on your roof plan, you now have all that you asked for.
Underlay Line Weight |
Thu, Sep 10, 2015 at 11:02:58 AM
Underlay Bug/Glitch when Zooming in and Out |
Wed, Sep 17, 2014 at 9:36:52 AM
Underlay |
Thu, Oct 11, 2012 at 8:15:33 AM
Detail Underlay |
Mon, May 17, 2010 at 11:47:22 AM
Underlay is not working |
Mon, Apr 28, 2014 at 5:29:50 PM
