Forums >> Revit Building >> Technical Support >> Sloped Slabs
Thu, Sep 7, 2006 at 9:54:10 AM | Sloped Slabs
jeeptomaso
I am currently working on a project that has a huge podium deck above a below grade garage. This podium deck has two different buidings on it and has a street funning in between the two buildings. Now to my question, this podium deck is sloping all over the place, is there any trick out there to get Revit to create a warped slab? We all know in the real world conc. slabs don't just slope one direction. Any and all ideas welcome, thanks in advance.
Thu, Sep 7, 2006 at 12:29:32 PM | RE: Sloped Slabs
Jerome111
3 Stars: 2 Votes
maybe use a "roof" to create the slab. extruding an arc for the side to side slope and the pitch for the front to back slope.
Thu, Sep 7, 2006 at 5:47:05 PM | RE: Sloped Slabs
eldados
eldados Avatar
4.5 Stars: 8 Votes
I wrote a tutorial just to do that Smile complex slabs and walkways... happy reading
Integrator
KarelCAD
Thu, Sep 7, 2006 at 11:07:35 PM | RE: Sloped Slabs
vnd
3 Stars: 2 Votes
Where is the tutorial?
VND
Thu, Sep 7, 2006 at 11:53:54 PM | RE: Sloped Slabs
puzzle
4 Stars: 10 Votes
It located in the Tutorials by Revitcity
Macca
Sunshine Coast
QLD Australia
Thu, Apr 12, 2007 at 3:40:08 PM | Sloped Slabs
leonardo1133
5 Stars: 2 Votes
mmm... and where is the tutorial section?
Thu, Apr 12, 2007 at 4:07:03 PM | Sloped Slabs
TomDorner
4.5 Stars: 25 Votes
The tutorials are located at:
http://www.revitcity.com/tutorials.php
Slabs become much easier in Revit Architecture 2008.  You can simply add points to them and give them a positive or negative height and the slab will adjust.  You can set if the whole slab slopes or just the top surface.
Tom
Thu, Apr 12, 2007 at 4:17:34 PM | Sloped Slabs
leonardo1133
5 Stars: 2 Votes
Nice "eldados" do you have some trial version of Revit 2008 ?
 By the way.. i checked your tutorial but i have problems to follow your steps.. before to beging i have been created a slap already?
:oS sorry but i trying to emigrate to Revit from Autocad.
Thu, Apr 12, 2007 at 4:49:08 PM | leonardo1133
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting leonardo1133 from 2007-04-12 16:17:34
RAC08 has now been released.  There are a few handy little toys you'll like in there.  Note with the new Floor and Roof point edit tool your sketch cannot have curved segments.  However, the workaround is to create the sketch with straight edges then use the opening tool to cut the sketch to the appropriate shape.
Regards,
Chris.
Thu, Apr 12, 2007 at 5:35:58 PM | Sloped Slabs
eldados
eldados Avatar
4.5 Stars: 8 Votes
saves so much time with the new tool! at last we got it Smile
Integrator
KarelCAD
Thu, May 24, 2007 at 12:55:59 PM | Sloped Slabs
luisrpv
Finally I'm in.
Ok I also have that same problem with having a warped slab. I have done the tutorial by eldados, worked great, but I cant trim or cut the roof to make it fit perfectly. I am on Revit 9.1. How can I get in on Revit Architecture 2008 and do the sloped slabs work in this new version. I was under the impression that it only worked for Revit Structure 2008.
Thu, May 24, 2007 at 5:38:40 PM | Sloped Slabs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Of course they work.
If you are on subscription you should have received a DVD of RAC2008 well and truly by now.  Alternatively you can download it from Autodesk Subscription Centre.
Edited on: Thu, May 24, 2007 at 5:38:53 PM
Regards,
Chris.
Sat, May 26, 2007 at 1:41:18 AM | Sloped Slabs
#13
Erik
I found tiling does not show right when I use the slab shaoing tool.  (I have another post re this, but has no bites) I draw as I build so I use a structural slab and a finishing slab on top
Sloped slabs and spot elevations
Thu, Mar 6, 2008 at 1:18:13 PM
Concrete Slabs with compound angles???
Wed, Feb 4, 2009 at 11:28:45 AM
recesses in slabs
Thu, Sep 29, 2005 at 3:33:42 AM
Floor not displaying right.
Sat, Feb 7, 2009 at 6:34:04 AM
slopped pad
Fri, Jun 23, 2006 at 9:42:32 AM
Page generation time: 0.3645
