Forums >> Revit Building >> Technical Support >> Family
Fri, Oct 8, 2004 at 6:40:58 AM | Family
barboumatt
hi being new to revit i know little about families but I would like to know.. how to create a piece of furniture/window/door etc where the dimentions can be altered by going through the properties tab in the model. ie without changing the original family and resaving as something else.
Matty B
Fri, Oct 15, 2004 at 9:24:09 AM | RE: Family
Rythmick
5 Stars: 2 Votes
Matty, that would be done by creating or editing the family and using dimensions where you want possible changes and assigning them a parameter by picking the dimension and using the "Label" pull down menu to <add parameter>. Mike Lenz
Create a family that includes another family
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family?
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message
Wed, Aug 26, 2020 at 11:19:36 AM
Text(family #1) not showing after loading into family #3
Mon, Jan 19, 2015 at 2:43:21 PM
Page generation time: 4.2687
