Forums >> Revit Building >> Technical Support >> revit 9.1 upgrade
Wed, Sep 6, 2006 at 4:23:26 PM | revit 9.1 upgrade
chrisd2
Is it just me? I have recieved my 2 cds which came with no instructions and tried running disk 1. As a result of instructions on the screen I have uninstalled my earlier version of acad 2007 and reinstalled from the new cds. But - No changes to Revit. I have searched on the web and the readme files but can find no guidence. I have spent 2 hours so far trying to figure out what to do but who is going to pay for my time? I do wish Autodesk would try and make life easy for once. Can anyone help?
Wed, Sep 6, 2006 at 5:12:52 PM | RE: revit 9.1 upgrade
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you look on the Revit DVD there is a subfolder with the 9.1 new features and release notes on it. HTH.
Wed, Sep 6, 2006 at 5:31:26 PM | RE: revit 9.1 upgrade
chrisd2
Thanks for the info. I do not have a dvd reader in my pc and the cds do not seem to contain any such info. It seems incredible to me that I should reieve Revit 9.1 cds that won't load the software.
Wed, Sep 6, 2006 at 7:41:49 PM | RE: revit 9.1 upgrade
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
So you can't get it to install? What is the error you're getting trying to install? I thought you were just after info on whats new in 9.1? If you're having trouble with your CD's download revit from the website. http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=7142518
Thu, Sep 7, 2006 at 12:19:31 PM | RE: revit 9.1 upgrade
chrisd2
Thanks for your suggestion. I did not want to download the upgrade - I thought it would take several hours or more. It did. If the cds had been quality assured before being dispatched I would not have wasted 1/2 a day.
Fri, Sep 8, 2006 at 10:35:50 AM | RE: revit 9.1 upgrade
drock1627
I Talked to my dealer, he said that the only changes to 9.1 were compatibility w/ revit struct. he said that unless you were using revit struct you would not see any difference between 9.0 and 9.1....
Sat, Sep 9, 2006 at 2:07:16 PM | RE: revit 9.1 upgrade
MarkyF
Sounds like you have sorted this out now but when I received my upgrade disks I too thought where is the revit upgrade after loading the 2 disks. I actually found an additional disk inside the box hidden behind the revit getting started guide...DOH!!
Sun, Sep 10, 2006 at 7:18:43 PM | RE: revit 9.1 upgrade
psymon
psymon Avatar
3.5 Stars: 6 Votes
Revit 9.1 was issued on a DVD for the first time. If you do not have a DVD drive you will not be able to read them. Inform Autodesk that you would like to receive further upgrades in CD format or buy a DVD drive. HTH
Mon, Sep 11, 2006 at 11:57:47 PM | RE: revit 9.1 upgrade
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not sure who told you, you wont notice any difference between 9.0 and 9.1. As always with revit upgrades, once you've upgrade a file to 9.1 you will no longer be able to open it in Revit 9.0. There are a number of new features, but it is only a minor release and nowhere near as many features as say the 8.1 to 9.0 releases. HTH.
UPGRADE QUESTION
Mon, Jun 12, 2006 at 9:03:39 AM
UPGRADE problem!!!
Wed, Jun 28, 2006 at 6:35:24 AM
Revit 2011 upgrade
Fri, Jul 2, 2010 at 7:15:32 AM
Revit Upgrade from 2009 to 2012
Wed, Oct 19, 2011 at 7:08:21 AM
Revit MEP 2011 Upgrade from 2010 pricing
Thu, May 20, 2010 at 10:31:17 AM
Page generation time: 2.5874
