Forums >> Community >> The Studio >> Room Tags and Detached Walls
Wed, Sep 6, 2006 at 3:16:01 PM | Room Tags and Detached Walls
trich00
I have created some walls - (Conc. Shear walls) and have detached them - Disallowing join so they do not join with furring walls or other walls near them - These walls also extend 30 floors - this was need to keep the walls from joining and moving around from floor to floor. No I have tried to insert room name/tags with rooms using the shear wall as one of the room wall s- Well the room name tag does not find the room because the wall is detached - Does anyone no how to resolve this?... Do I have to put in room separation lines at every location - or should I be making my shear wall out of a column family to keep if from joining to walls - Any suggestions on what has worked for others...
Wed, Sep 6, 2006 at 5:19:26 PM | RE: Room Tags and Detached Walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Provided the room is bounded by walls on all sides there should be no issues with using the disallow join effecting the room closure... Perhaps a screenshot would help see the issue?
Thu, Sep 7, 2006 at 2:20:16 AM | RE: Room Tags and Detached Walls
johann
Mr Spot, Could you please explain the concept and working of 'screenshot'. I have tried the Revit Help comand but I am still at a loss. Thanks
Tue, Sep 12, 2006 at 12:00:07 AM | RE: Room Tags and Detached Walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use ctrl+Prt Scn to capture an image to the windows clipboard showing your issue then paste it into a graphics program and upload here. In your situation there could be numerous things causing the room to not bound correctly.
room tags and floors
Thu, Jan 26, 2006 at 3:54:41 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:12 PM
Can't get Rooms (Room Tags) on Second Level...
Sat, Mar 21, 2009 at 3:44:40 PM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Demo Plan Room Tags
Thu, May 12, 2022 at 9:21:44 PM
Page generation time: 0.4193
