Forums >> Revit Building >> Technical Support >> Elevation bugs show up out side of Crop Region on sheets.. Why?
Tue, Sep 5, 2006 at 7:03:58 PM | Elevation bugs show up out side of Crop Region on sheets.. Why?
iREV
3.5 Stars: 3 Votes
I have a problem with the interior elevation bugs showing up out side of my crop region. I cannot VG them off because I have Intereior Elevation bugs on the inside of my crop region. Is there a way to turn these off with out creating new types of elevation bugs?
Wed, Sep 6, 2006 at 1:43:17 AM | RE: Elevation bugs show up out side of Crop Region on sheets.. Why?
johann
I have had a similar situation. I sort of solved it by un-ticking the bugs that I don’t want and shortening the elevation line to as-short-as-it’ll-go and hoping that nobody would mind the 5mm line on the side of my page. I hope this helps. It would be nice if the next Revit solved this by allowing hidden objects not to be printed.
Wed, Sep 6, 2006 at 9:51:35 AM | RE: Elevation bugs show up out side of Crop Region on sheets.. Why?
holly1
Click on tag right click hide annotation
Wed, Sep 6, 2006 at 6:32:44 PM | RE: Elevation bugs show up out side of Crop Region on sheets.. Why?
iREV
3.5 Stars: 3 Votes
Thank you. Holly your way worked great!
Wed, Sep 6, 2006 at 7:38:06 PM | RE: Elevation bugs show up out side of Crop Region on sheets.. Why?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This occurs if the actual elevation line is still within the crop region - (as the elevation "bugs" -haven't heard that before- can be separated from the view itself). If you can move this elevation line outside of your crop region then this will prevent this issue in the future. Hide annotation in view works on all views, levels and grids. Post edited on 2006-09-06 19:38:32
MAKING HIDDEN OBJECTS NOT SHOW UP WHEN YOU PRINT.
Fri, Feb 6, 2004 at 7:13:30 AM
Can't get Crop region to be visible in my elevations views
Tue, Dec 2, 2008 at 8:42:39 PM
My dependant elevation view tag will not show up in my dependant plan view
Tue, Jan 8, 2008 at 11:47:57 AM
crop region changes when placed on sheet
Fri, Jan 9, 2015 at 3:33:07 PM
Interior Elevation - Crop Region - "lineweights"
Tue, May 8, 2007 at 10:25:02 AM
Page generation time: 0.6693
