Forums >> Revit Building >> Technical Support >> Material Takeoff issue
Mon, Sep 4, 2006 at 3:09:58 PM | Material Takeoff issue
TGW
I have generated Material Takoffs but some items show up moe than once on the schedule, some 2 or 3 times. I am trying to generate a cost estimate from the Material Takeoff. I have been using REVIT since version 2 and this one I can't seem to resolve. Thanks for any help.
Mon, Sep 4, 2006 at 5:32:09 PM | RE: Material Takeoff issue
TGW
OK I think I have it now. The Material Takeoff function developes a line item for each component of an assembly. This appeared to me that each assembly was being repeated. So I guess the best way to develop a prelim cost schedule is to use the Quantities/Schedule function instead of the Material Takeoff function. Post edited on 2006-09-04 17:32:34
Tue, Feb 13, 2007 at 2:54:38 PM | Material Takeoff issue
Jhui
This is an old thread but I'm having a similar issue, why is each assembly being repeated?
Mon, Sep 29, 2008 at 1:34:20 PM | Material Takeoff issue
JStack
In the properties of the material takeoff or schedule, under the "Sorting/Grouping" tab, do you have "Itemize Instances" checked at the bottom?  If so, then this is most likely your problem.
Mon, Oct 25, 2010 at 3:48:35 PM | Material Takeoff issue
amandaholly
Itemizing every instense or not only changes how is is displayed not how it is totalled.
Thanks for this posting guys.  I tested both methods (Material takeoff schedule and Wall type with areas achedule) and was confussed by the extreme difference in area totals.
Material Takeoff
Mon, Apr 27, 2015 at 7:32:15 AM
REVIT 2015 material takeoff, gross area issue
Wed, Sep 3, 2014 at 10:23:45 AM
11
Ceiling Material Takeoff
Thu, Feb 15, 2007 at 3:19:57 PM
Material Takeoff for insulation??
Mon, Oct 28, 2013 at 9:57:10 AM
Sheathing Material Takeoff
Mon, Apr 25, 2011 at 7:01:06 AM
Page generation time: 0.3159
