Forums >> Revit Building >> Technical Support >> How can I freeze groups?
Mon, Sep 4, 2006 at 8:43:56 AM | How can I freeze groups?
marsupilami
I would like to be able to "freeze" groups in order to avoid any automatic connections to the "outside world". I am working on a layout where I have many rooms which are exactly the same, but moving them around (as groups) is extremely annoying, because the walls inside the group always try to connect to other elements outside the group or to elements of the other group next to it. Also, the performance with 120 rooms as groups in one project became unacceptable, moving a simple wall takes 3 minutes because of the groups present in the model.
Mon, Sep 4, 2006 at 9:35:17 PM | RE: How can I freeze groups?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Edit the group and edit any wall ends (by right clicking and selecting disallow join) that are interacting with elements outside of the group. This should speed it up and give you greater control. HTH.
Regards,
Chris.
Tue, Sep 5, 2006 at 2:58:53 AM | RE: How can I freeze groups?
marsupilami
Ok, I went back and split the building into two projects and this helped, too. However, a temporary freeze or "isolation mode" for groups would be handy. Thomas
Thu, Sep 21, 2006 at 7:43:57 AM | RE: How can I freeze groups?
Chymos
Would perhaps putting the groups on a separate workset and use Revit's selective loading capability help in this case? May be worth a shot...
Thu, Sep 21, 2006 at 8:39:03 AM | RE: How can I freeze groups?
marsupilami
That will be the approach I will try if the project (was a competition) continues. Haven't played much with worksets yet, but this sounds promising.
Thu, Sep 21, 2006 at 8:48:23 AM | RE: How can I freeze groups?
Chymos
We use worksets extensively as we regularly have multiple users in the files. Let me know if you have any questions.
Thu, Sep 21, 2006 at 10:06:39 AM | RE: How can I freeze groups?
gdoorn
1 Stars: 1 Votes
this is exactly what i have done with a 13 story condo-conversion i am working on. i created groups for my unit plans, i edit one, they all update. then i put all of these groups on a Unit Interiors workset so i can turn them off in necessary sheets/views to better control my end-product. as of now, i am the only user on this project (however this is going to change soon), but i still have 6 worksets created to allow me to control the visibility of things better.
Freeze Drawings in 2012
Fri, Jan 11, 2013 at 9:12:42 AM
Groups and Phases
Thu, Jan 29, 2015 at 10:45:27 PM
Inserting multiple Families causes project to freeze
Fri, Jul 11, 2008 at 3:28:40 AM
Revit 2008 Groups
Tue, Apr 17, 2007 at 2:08:31 PM
Many Small Groups OR Few Large Groups
Mon, May 12, 2014 at 9:59:30 AM
Page generation time: 0.0586
