15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Relocating Project
22 Posts No Rating |
I have set up a model that has a shared and a project elevation base. I have set the shared parameter to the right height and my project parameter currently reads 0'-0" for the first level. I would like it to read 100'-0". What is the best way to accomplish this without losing my shared elevation or my mind.
-Thanks for any help
31 Posts No Rating |
go to an elevation view...say east
right clik on base elevation 0'
properties
near the top hit edit / new on the 'head'
toggle elevation base to 'shared'
ok ok
then go 'settings'
locations and coordinates
relocate this project
highlight level one and move it up 100'
bob as they say is your uncle
cc
Using this method changes my shared project elevation which I would like to read 5410'-0". How do I get a project elevation of 0'-0" while maintaining my shared elevation?
30 Posts No Rating |
relocating the project will adjust the shared coordinates, but it won't help you with your project coordinates. to adjust the project coordinates, you need to find your base point in either an elevation or a section, unclip it, and move it to the desired elevation. in this case, you would unclip the basepoint and move it up 100'.
HELP..text relocating....project due |
Wed, Sep 28, 2005 at 10:07:40 AM
Can't align Sturctural and Architectural model project positions. |
Tue, Aug 14, 2012 at 6:59:52 AM
Topographical Surfaces |
Thu, May 10, 2012 at 7:18:29 AM
Moving/relocating connected systems |
Wed, Feb 25, 2009 at 10:16:45 PM
Relocating elevation of building |
Tue, Jan 15, 2008 at 2:59:13 AM
