38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimensioning grids
Fri, Sep 1, 2006 at 6:21:10 AM | Dimensioning grids
Akiko
Hi, I am trying to dimension the grids so that the grids' dimensions will show all the floor plans. But with Revit dimension tools, the dimensions I draw only show up on that particular floor plan and not other floors. This means I have to repeat grid dimensioning 12 times since I have 12 floors. Any idea to dimension so that it always shows on any floor plans?
Fri, Sep 1, 2006 at 7:30:53 AM | RE: Dimensioning grids
krmccurdy
Two options. Either cut and paste your dimensions from view to view. Or after you've got one view dimensioned, use the "duplicate with detail" option when duplicating a floor plan. If you've got view filters set up (you can just create them from your existing views quickly), then it will be easy to reset everything in each view type once the views are dupilcated.
Fri, Sep 1, 2006 at 9:25:20 AM | RE: Dimensioning grids
TomDorner
4.5 Stars: 25 Votes
Remember. that ALL annotation in Revit is view specific. This means all text, dimensions, tags, detail lines etc. As the previous post mentioned, copy and then paste alinged is a good option. You could also group the dimensions and copy the group around to different views. HTH Tom
Fri, Sep 1, 2006 at 9:28:29 AM | RE: Dimensioning grids
Akiko
copy/pasting worked. Thanks for help.
Fri, Sep 8, 2006 at 1:55:08 PM | RE: Dimensioning grids
Hazem
VERY EASY: make the dimensions a group and paste them on every plan view Simple !!!!!!!
Thu, Sep 21, 2006 at 7:40:18 AM | RE: Dimensioning grids
Chymos
Haven't tried the grouping option. Honestly, never thought of grouping dimensions. Hazem, how has this worked for you in the past? Are you happy with the results? Sorry to just be plain lazy this morning and could try it quickly myself, but I wanted to see how you liked it over the life of a project.
Thu, Sep 21, 2006 at 9:02:59 AM | RE: Dimensioning grids
stevelj
No need to make them a group, groups suck in plain english, select dims, copy to clipboard, use Edit Menu, pull down and select which levels you want to paste to.
Thu, Sep 21, 2006 at 9:50:34 AM | RE: Dimensioning grids
Chymos
stevelj, that is what we do currently, but it's not fun if a dimension changes, particularly on my current project that has 10 stories over parking. Say a witness line needs to reference a different object than what was originally selected or we need to add a witness line to the string. We have to then open each view, delete the strings, go back to the original view, modify the string as needed, copy clip, and paste aligned again to all other views. It would be great if we only had to do it once, and the group would update all other levels.
DIMENSIONing GRIDS - on plan view
Thu, May 26, 2011 at 1:33:19 PM
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
new user - copying grids to other levels
Mon, Dec 6, 2010 at 3:06:35 PM
multiple scope box for grids
Tue, Sep 1, 2015 at 8:35:46 AM
Page generation time: 2.0237
