24 Users Online (22 Members):
Forums >> Community >> The Studio >> Moving grids
4 Posts No Rating |
I have a project that is approx. 10032kb in size and another project that is 8528 kb. When I try to move, drag, or change a dim in order to get a grid line (with columns and walls) to move the program will think for a while and then crash. When I do the same thing with a file the size of 2328 kb the commands work just fine. Has anyone else had this problem or know of a fix? The message that is displayed is attached.
33 Posts No Rating |
I don't know what version you're in, but I've had similar expereinces in 8.1. Usually it's been when I've tried to do the exact same sequence when, for example, editing a ceiling, and always on a workset enabled project. The way I've worked around it is to do a different sequence of events, saving after each step until I get past the point where I've had the problem in the past. No idea why it works, but it's saved me about a dozen times. FYI, the size of project I've had issues with has been on the order of 150Mb.
You might also try to audit your file when you open, too.
Moving beams and joists with grids |
Wed, Mar 2, 2011 at 11:56:25 AM
Grids at an Angle in Plan don't display in Elevation |
Thu, Apr 26, 2012 at 2:44:38 PM
new user - copying grids to other levels |
Mon, Dec 6, 2010 at 3:06:35 PM
multiple scope box for grids |
Tue, Sep 1, 2015 at 8:35:46 AM
Moving a Portion of a Building |
Wed, Dec 14, 2011 at 6:20:51 PM
