Forums >> Revit Building >> Technical Support >> journal files
Thu, Aug 31, 2006 at 10:10:02 AM | journal files
Chymos
I know this sounds like a very general/basic question, but from what I hear, they are very powerful. What are JOURNAL FILES? Where are they found? How do you use them? I heard that you could basically convert them to text, drop them onto revit, and it would pretty much recreate an entire revit model.
Thu, Aug 31, 2006 at 10:30:27 AM | RE: journal files
jfurlong
there found at c program files revit 9 journalls they are powerful and can recreate whole drawing, BUT they only keep the jornal from every save. so unless you made your model with only one save i don't think they will be usefull for you. i use when swapping 2D familes for 3D families. if you let me know what exactly your trying to do, i'll try to help.
Thu, Aug 31, 2006 at 10:37:17 AM | RE: journal files
Chymos
Thank you for thr prompt reply. I found them about 2.3 seconds after I sent the post... If patience is a virtue, I am not a very virtuous person... I am sending a corrupted file to the AutoDesk Subscription folks and they requested the journal file along with a few other items. They are attempting to recreate a crash I had this morning because of a simple family containing nothing but a simple extrusion and an associated object style. The technician mentioned the journal file being able to basically recreate the file from the last save. This has been a desire of mine on a number of other jobs in our office because a particular user had not saved in a long while before a crash. This doesn't happen a lot, but when we could potentially lose hours of work, it would be a sweet trick to try.
Thu, Aug 31, 2006 at 10:55:13 AM | RE: journal files
Chymos
Also, how do the journal files work in relation to the CENTRAL file vs. the local user file? I cannot imagine how a local user's journal file would be applied without potentially messing up another user's work.
Thu, Aug 31, 2006 at 10:56:47 AM | RE: journal files
jfurlong
first off- i made a mistake in the last post. the jornal keeps track of all key strokes from when it was opened to when it was closed not from SAVE to SAVE. SORRY.
yep i see what you are trying to do.
it can sometimes be used for this.
it is sometimes very hard to do.
make a practice file
goes something like this
you open revit
you open a file say called "jonathans-house"
you work on the drawing for say 5 hrs and you don't save.
then the drawing crashes.
first thing to do is
find the jornal file
make a copy of it for back up incase u curse it up
edit the file in note pad
i normally delete out the last 10 commands
make sure you take out the close command.
example
Jrn.Directive "WindowSize" _
, "[test2.rvt]", "Floor Plan: Level 1" _
, 506, 381
, 710, 361
, "[test2.rvt]", "Elevation: East" _
, 538, 588
, 742, 568
Jrn.Directive "ActivateView" _
' idle0_doc
' SC_CLOSE
then resave the file
then make sure all revit sessions are closed
the drag the jornal file onto the revit icon.
it does work if you get it right.
Thu, Aug 31, 2006 at 11:01:59 AM | RE: journal files
jfurlong
it get very mess if there are worksets involved but can be done, i would never practice this kind of thing on a live project, instead make a small model and when no one is in the office practice it. post your email address and ill forward you a tutorial that i have prepared that makes use of the jornal file. not for exactly what you want to do but it may be a good starting point for you.
Thu, Aug 31, 2006 at 11:07:25 AM | RE: journal files
Chymos
Trying a "dog house" right now. I'll try a regular file first, then rope another "qualified user" into trying a "workset divided" version. I would love to see the tutorial. Thank you very much. email is jcary@ncgarch.com
Thu, Aug 31, 2006 at 11:10:30 AM | RE: journal files
jfurlong
file is on the way, this tutorial hasn't been 100% finished so please don't distribute it. it works put still has get the finishing touches.
Thu, Aug 31, 2006 at 1:52:09 PM | RE: journal files
Chymos
Thanks again. These journal files seem to be VERY powerful in the right hands. I was able to recreate a "days work" that was "lost" in a simulated crash. It's really cool to watch Revit trace your steps... I have many variables to try out (multiple files loaded in a single Revit session, worksets, design options, etc.), but I am very optimistic. While we try to tell users to STC often, sometimes they do not listen and lose valuable work in a crash or a freeze up. This gives us a way to recoup some of the work.
Rev 2009 Journal Files
Thu, Sep 1, 2011 at 9:04:39 AM
Journal Files
Wed, Jan 25, 2012 at 3:44:43 PM
I don't have Journal Files!
Sat, Nov 15, 2008 at 2:19:10 AM
12
Revit 2012 - Try to recover rvt file from Journal Files
Mon, Jun 25, 2012 at 12:16:27 PM
Execute Journal File through Batch File
Tue, Jun 14, 2011 at 9:43:14 AM
Page generation time: 5.7973
