Forums >> Revit Building >> Technical Support >> Color fills
Thu, Aug 31, 2006 at 10:03:13 AM | Color fills
JHanby
3.5 Stars: 3 Votes
I have applied color fills to all the rooms on the floor plan. On one room, the color shows up in the legend but not the room itself. What could be the possible cause for this. I have deleted the tag several times and reinserted it but it still doesn't show up.
Jill
Thu, Aug 31, 2006 at 11:10:03 AM | RE: Color fills
Dgodfrey
4 Stars: 4 Votes
I've noticed duplicate tags on my schedules which lead me to think there are "hidden" room tags lurking somewhere which is probably the room you are adding fill to and not the room you are intending. Do you have the same room name listed more than once? Rename the room something unique so you are certain the name in the fill schedule is the correct room you are adding fill to.
EXPORTING TO AUTOCAD- WITH NO COLOR FILLS
Sat, Mar 31, 2018 at 3:07:56 AM
Turn of Color Fills
Fri, May 19, 2006 at 2:31:06 AM
Room Color Fills from one model to another linked model
Thu, Apr 8, 2010 at 10:40:57 AM
Shading Ductwork and Air Terminals on plan
Tue, Oct 19, 2010 at 2:39:20 PM
**URGENT HELP NEEDED** Graphics Issue With Color Fills
Mon, May 19, 2014 at 6:44:25 PM
12
Page generation time: 0.1291
