Forums >> Revit Building >> Technical Support >> Compatibility of Revit and AutoCAD
Wed, Aug 30, 2006 at 12:13:07 PM | Compatibility of Revit and AutoCAD
Letmethinking
Hey Guys, Hows the compatibility between the two softwares? Are you able to work flawlessly between the two? How about consultants? Structural Guys. Any complaints? Need some advice. We are planning to switch to Revit from DataCAD Thanks in Advance
Thu, Aug 31, 2006 at 4:23:04 PM | RE: Compatibility of Revit and AutoCAD
bigstein
i've got the same question. I'm working a project that is in design development. My structural engineer has built his model based on mine. We both plan to supplement the CD's with CAD details from our libraries. The issue I have is my other consultants, MEP and Civil are not Revit savvy and will be working strictly 2D. I imagine I'll need to export 2D plans to AutoCad frequently. So far, I've been able to go back and forth (but it's been with small files). I've also been able to import a sketch up model into Revit as a mass.... Utlimately, my firm wants to be on Revit - we don't want to fall victim to the contractors who are doing more and more in 3D.
Release Compatibility Structure - Architecture - Etc?
Tue, May 17, 2011 at 1:57:25 PM
Compatibility throughout Autodesk
Wed, Jun 4, 2008 at 10:08:22 AM
Revit 2010 on win 7 w/xp compatibility mode?
Mon, Jan 30, 2012 at 5:54:41 PM
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
REVIT COMPATIBILITY WITH GREEK DRAWING CODE!
Tue, Dec 5, 2006 at 1:45:42 AM
Page generation time: 2.6830
