32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> fatal error
21 Posts No Rating |
i am now consistantly getting a fatal error when i try to edit an opening (from the modeling tools). i have edited it's plan width in the past, but for some reason, this morning i started getting fatal errors... anyone else experience this...
I have had some weird problems like this before. For me it was a curved wall. Any way that I tried to edit it I recieved an error that told me to save the model as a new name before continuing. At the same time that I recieved the error the wall would return to its original state. I tried two things that I think together did the trick. First I offset a copy of the wall, so that I wouldn't lose the doors and windows in it. Then I flipped the wall with the little blue flip arrows. For some reason when I flipped it, it allowed me to delete the original wall. Then, I just offset the copy back into the original location.
Maybe a similar series of steps will help you get past this stuburn opening. Or just delete it and draw a new one.
ArchWestCY
thanks, i'll see what's going on... it seems strange that the opening would be relative to the baseline of the wall...
yeah, to get past it for now, i just deleted it and made a new one...
it also seems strange that you can't edit the width of the opening in the properties, but you can edit the height...
Fatal error on a shared job Revit 2015 |
Tue, Mar 15, 2016 at 1:06:32 AM
Fatal error when in any type of sketch mode |
Wed, May 16, 2018 at 11:28:43 AM
Fatal Error when adding casework tag |
Mon, Apr 6, 2009 at 12:38:40 PM
Fatal Error - Keynoting |
Sat, Feb 5, 2011 at 10:18:08 AM
Fatal error inserting components |
Mon, Nov 24, 2008 at 7:26:38 PM
