Forums >> Revit Building >> Technical Support >> Pad problem
Wed, Oct 6, 2004 at 4:05:05 PM | Pad problem
nsoba
According to Revit, pads can share edges but not overlap. I tried aligning edges to a reference plane but get an overlapping error. If I offset even 1/256", I can make the pad but I get the topo surface not being cut in that small area.
Thu, Oct 7, 2004 at 12:47:48 AM | RE: Pad problem
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When a pad intersects a toposurface it automatically joins itself making it no longer possible to snap to the edge points. Try drawing you pads well above the toposurface and align them first. Then lower the pads to the correct locations. I attempted sharing edges with a pad and had no problem if i drew a reference plane in first where i want the shared edge to be. Hope this helps. Cheers.
Thu, Oct 7, 2004 at 9:53:02 AM | RE: Pad problem
nsoba
Solution: I edited the pad sketches, and instead of aligning the old lines to the reference planes, I erased them and redrew the areas using the rectangle tool. Perhaps there is some angular fuzz or something when just using lines/align that is avoided when using rectangles. Post edited on 2004-10-07 09:54:03
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:08 PM
building pad as a host for in-place mass problem
Fri, Mar 4, 2011 at 1:38:26 PM
Topo hatch disappear under building pad
Mon, Jan 27, 2014 at 8:27:53 AM
Cannot choose edge of a pad in Revit 2010
Sun, Feb 21, 2010 at 5:16:33 AM
Topo slopped pad (parking lot/road)
Mon, Aug 24, 2009 at 8:26:23 AM
Page generation time: 1.6837
