Forums >> Revit Building >> Technical Support >> Camera lens adjustment
Tue, Aug 29, 2006 at 9:47:19 PM | Camera lens adjustment
JebG
I have been searching for a way to adjust the aquivalent of a lens in Revit Whenever I create a camera the view begins too small, then when I stretch out the window box in the view the view becomes far too distorted to use. I usually would specify a camera lens between 18 -35mm in Autocad or other programs, is this possible? Help would be much appreciated ! ! !
regards JebG
Tue, Aug 29, 2006 at 10:04:09 PM | RE: Camera lens adjustment
TomDorner
4.5 Stars: 25 Votes
I believe that when you place a camera the lens is equivelant to 35mm. To adjust the secne, you should not stretch the view box. Rather you should explore using the camera adjustments by pressing F8 and using those tools. You can also move the camera in a plan or elevation view by going to the plan or elevation/section and then right click on the 3D view and activate "show camera" HTH Tom
Tue, Aug 29, 2006 at 10:41:09 PM | RE: Camera lens adjustment
JebG
Thanks That does help a bit, I discovered that there are a few more settings within the Dynamic view dialogue -field of view, which certainly helps adjust the view. Still no sign of a setting to adjust the default lens from 35mm to 18mm or other. Appreciated
regards JebG
Wed, Aug 30, 2006 at 6:56:33 AM | RE: Camera lens adjustment
Although it doesn't give you a lens size, the Dynamic view dialogue -field of view does adjust the lens. Back out a ways and you'll see that the lens is no longer a "normal" lens.
Sat, Sep 9, 2006 at 12:03:58 PM | RE: Camera lens adjustment
chrisd2
I have the same problem trying to re create an 18mm lens and have adopted the same approach as yourself, As far as I can make out the Angle of View for an 188mm lens is 69degrees and I try to adjust the view box to give me this. It is not perfect and I have come across other problems ie the camera was not perfectly levl when taking the shot. Being able to enter a value for the AoV would be a great help. Hope you find an answer. Chrisd.
Camera Views In Plan (TARGET ADJUSTMENT)
Sat, Oct 30, 2010 at 8:16:47 AM
Virtual Tours - Rendering requirements for camera setup in Revit.
Thu, Sep 8, 2011 at 12:29:53 AM
Camera-Icon interactive placed with camera
Thu, Sep 3, 2009 at 10:57:30 AM
Can't create camera or walkthrough on first floor but can on others. Why?
Wed, Nov 19, 2014 at 10:32:39 AM
revit into photoshop to scale
Mon, Mar 21, 2011 at 11:43:56 AM
Page generation time: 4.6254
