18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> wood bracket placement on columns help
3 Posts No Rating |
In reference to the wood bracket from the family explorer, how do I attach this to columns instead of walls?
Not sure what "wood braket" you are refering to. Did you create it, or find it in a library or online?
Chances are that the creator used a wall hosted template to create it which means it will only use a wall as a host. A better creation method is to make a non-hosted version you embed into the hosted version.
You may have to re-create a new non-hosted or workplane based verion. Post the .rfa and maybe somone can take a look at what is involved.
HTH
Tom
Adaptive component - Bracket |
Mon, Oct 12, 2015 at 6:11:04 PM
rail on ramp with constant height bracket? |
Fri, Jan 8, 2010 at 1:52:17 PM
recalcitrant columns |
Tue, Aug 3, 2004 at 7:38:46 PM
RAIL - WALL BRACKET |
Wed, May 3, 2017 at 3:05:00 PM
Handrail Bracket to rotate with slope of railing |
Fri, Jul 6, 2012 at 10:16:39 AM
