Forums >> Revit Building >> Technical Support >> Dimension String
Tue, Aug 29, 2006 at 5:55:23 PM | Dimension String
palmer
This is a dull detail, but I am often annoyed in my search for an empty field to click and end a dimension string. Often over heavy patterns or background lines (sometimes invisible) I find another unintended element receives dimension. Is there another command / work around to end dimension strings? pH
palms
Wed, Nov 22, 2006 at 2:00:05 PM | Dimension String
normanoid
Nope. I feel for ya.
Wed, Nov 22, 2006 at 3:05:15 PM | Dimension String
Your last click can be back inside your previous choice ... should be some room where your putting your dimension
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:58 AM
Adding a dimension to a dimension string...
Wed, Jul 10, 2013 at 3:42:09 PM
dimension string problem
Thu, Oct 18, 2007 at 1:21:31 AM
partially obscurred dimension string
Mon, Oct 29, 2007 at 10:45:13 AM
Having Dimension text in string, not above dimension string
Fri, Sep 25, 2009 at 12:18:08 PM
Page generation time: 0.4290
