Forums >> Community >> The Studio >> Floors - Constant-height-defining lines must be parallel??
Mon, Aug 28, 2006 at 7:15:31 PM | Floors - Constant-height-defining lines must be parallel??
rudyard
1 Stars: 1 Votes
Am trying to learn revit 8.1 and have become stuck when trying to add a floor. I have a 2 storey house and it is the first floor, 300mm timber - revit has a generic 300mm floor which im using. However I select the walls of the first floor (they do not sit exactly over ground floor walls) and when I finish the sketch I get the error message 'Constant-height-defining lines must be parallel' I change everything I can find in the properties but I just cant seem to get rid of this message. Im totally stuck, does anyone know the property setting I have wrong so I can add a simple floor??
Tue, Aug 29, 2006 at 12:38:25 AM | RE: Floors - Constant-height-defining lines must be parallel??
deboddy
5 Stars: 2 Votes
Have you first defined the level at which you want the floor to be at? For exampleif your floor is at Level 1 - go to the floor plan of this level and then either select walls or sketch lines to draw the floor. .
Deb
Tue, Aug 29, 2006 at 1:14:58 AM | RE:
rudyard
1 Stars: 1 Votes
Quoting deboddy - 2006-08-29 00:38:25
"Have you first defined the level at which you want the floor to be at? For exampleif your floor is at Level 1 - go to the floor plan of this level and then either select walls or sketch lines to draw the floor. ."
Tried that but it doesnt seem to work. I just cannot get rid of this message. Does anyone know what it actually means?? I am at a loss.
I would attach the file but all my revit files seem to be massive (9mb with not much in the drawing).
rail on ramp with constant height bracket?
Fri, Jan 8, 2010 at 1:52:17 PM
NEED HELP ASAP ON CEILING!
Thu, Apr 26, 2007 at 5:18:14 PM
Dimensioning 2 non-parallel reference lines
Thu, Feb 14, 2008 at 9:40:47 AM
Dual Sloped Floor without Modifying Sub Elements
Sun, Dec 29, 2013 at 10:41:27 AM
Mass Floors with a Minimum Height/Clearance
Wed, Apr 18, 2012 at 5:25:50 AM
Page generation time: 0.5547
