Forums >> Revit Building >> Technical Support >> imported categories
Mon, Aug 28, 2006 at 12:12:06 PM | imported categories
trich00
Has anyone had any trouble deleting imported catagoies? DWG were pulled into revit as a import file. But it does not allow us to delete the import from the "object styles" Does anyone know how to remove these files from Revit?
Mon, Aug 28, 2006 at 3:28:13 PM | RE: imported categories
TomDorner
4.5 Stars: 25 Votes
My tip is to NEVER import an AutoCAD file. Use the "link" option which is like an xref. That way you can remove the link and all the AutoCAD styles via the "link manager" or by simply deleting the link Now that yu have imported the AutoCAD file, go to "Object Styles" and click on each layer and select delete. Tom
Removing Imported Categories
Sat, May 20, 2017 at 5:26:29 AM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Delete imported categories
Tue, May 23, 2017 at 10:26:44 AM
insert a cad file in section or elevation..
Tue, Apr 16, 2013 at 2:33:59 PM
Collapsing Browser Categories & Sub Categories
Wed, Mar 4, 2009 at 9:29:51 AM
Page generation time: 1.4110
