Forums >> Revit Building >> Technical Support >> HP designjet 500 + HPGL2 card
Mon, Aug 28, 2006 at 4:38:56 AM | HP designjet 500 + HPGL2 card
johann
We have recently purchased a HP designjet 500 with the HPGL 2 card. Once installed, we found that the plotter ran out of memory while printing even the smallest Revit drawings. To solve the memory problem we now send the drawings as bitmaps (the print process being in the PC), however, this process can take in excess of 20min before the first line is plotted. Naturally Revit is inaccessible during this time. Does anybody else have this problem and has anybody been able top solve it?
Mon, Aug 28, 2006 at 8:08:01 AM | RE: HP designjet 500 + HPGL2 card
Elmo
3.5 Stars: 4 Votes
Hi Johan have you tried asking your HP suppliers if the HP D 500's memory can be upgraded?
Mon, Aug 28, 2006 at 8:14:01 AM | RE: HP designjet 500 + HPGL2 card
stevelj
I have had this plotter for years and have not experienced the problem you are having w/Revit. I have also maxed out the ram for the plotter from day one. Are you trying to plot drawings with shadows? shadow plotting any view takes a very long time.
Mon, Aug 28, 2006 at 8:18:17 AM | RE: HP designjet 500 + HPGL2 card
johann
Elmo, hi. We have an additional 128MB memory card installed. I believe this to be the maximum currently available for this machine. I have spoken to the local Revit distributors, but they were unable to solve our little problem.
Mon, Aug 28, 2006 at 8:24:24 AM | RE: HP designjet 500 + HPGL2 card
johann
Stevelj, hi. Some of the drawings are with shadow and yes, they are slow to plot. However, even smaller drawings without shadows can take in excess of 15min. What setting are you using for both the plotter and Revit? Perhaps we have the combination wrong.
Plotters
Fri, Aug 12, 2005 at 12:01:40 AM
Designjet printer driver w/ Windows 7 - 64bit
Thu, Feb 17, 2011 at 11:20:24 AM
SmartBim Library for $500-Any opinions?
Fri, Nov 21, 2008 at 10:07:52 AM
Rotate Plot
Fri, Aug 12, 2005 at 3:29:25 PM
lumion graphics card use
Tue, Dec 2, 2014 at 2:03:22 AM
Page generation time: 0.7446
