Forums >> Revit Building >> Technical Support >> please help #2
Mon, Aug 28, 2006 at 1:55:41 AM | please help #2
sabiha
if you use the if formulaif ( height>3000metres....) how do you know what part of the formula refers to what in the parameter? the depth or the width?
Mon, Aug 28, 2006 at 8:18:33 AM | RE: please help #2
Elmo
3.5 Stars: 4 Votes
hi there if statements work as follows. If(Condition,True,False) Condition - This part is for you to control the if formula. In you example you would be saying that if the height is larger than 3000m. True - This is what you want to happen if your condition has been met.. So in other words if your Height is larger than 3000m then I want it to be 3000m. False - This happens when you condition hasn't been met. So I would say that if it is smaller than 3000m then I want it to be Height.
Tue, Aug 29, 2006 at 1:27:27 AM | RE: please help #2
sabiha
thanks so much Smile
Page generation time: 0.0064
