Forums >> Revit Building >> Technical Support >> Imorting AutoCad Titleblocks
Fri, Aug 25, 2006 at 6:15:58 PM | Imorting AutoCad Titleblocks
ewartleon
Hello all, I would like to find out from any of you guys about the best way of importing and saving an AutoCAD Titleblock from autocad 2006? Any suggestion, I was told this is the place for any solution to any problems. Thank you much
Fri, Aug 25, 2006 at 7:02:51 PM | RE: Imorting AutoCad Titleblocks
CJCoon
Hi Ewartleon, File>New>Titleblock File>Import/Link>CAD Formats Locate the titleblock you wish to use. Select the titleblock. Full Explode. Now you can modify it if you wish. Save as. Fin. If somebody else knows a better way or even a different way. Please let me know. Thanks, Kune
RHL Design Group Inc.
Titleblocks
Mon, Feb 20, 2006 at 4:39:37 PM
TitleBlocks
Fri, Dec 8, 2006 at 8:08:02 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:33 PM
Labels in Titleblocks?
Mon, Nov 10, 2008 at 3:30:01 PM
raster image issue when exporting titleblocks to dwg / autocad
Tue, Sep 9, 2008 at 12:12:42 PM
Page generation time: 0.1811
