Forums >> Revit Building >> Technical Support >> Tiling Layout
Tue, Oct 5, 2004 at 8:03:31 PM | Tiling Layout
ale02
ale02 Avatar
3 Stars: 3 Votes
Hi, It is me again. Seems like a problem boy huh?! Has anybody try to do tiling layout in Revit? at the moment, what I am trying is just change the floor or wall material and select ceramic wall finish and define using model fill patterns. Question, What if I want to do a tiling layout and show different type of tiles or show different type of type sizes? Doing it in family? again? (Is there any easier way, out of this?)
Tue, Oct 5, 2004 at 10:48:04 PM | RE: Tiling Layout
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Could check out to see if there has already been fill pattern with the feature tiles built into it? Otherwise you could splt the face of the floors where the features are to go and apply a different material/fill pattern.
Wed, Oct 6, 2004 at 1:28:49 AM | RE: Tiling Layout
hjin
Thanks, Never thought of that, Split surface. I think it will work well in applying different tiles materials in a particular standard layout. How about different special design layout especially for floor tiling layout with different tiles sizes, tile cuts and border tiles?
Adjust hatching to follow brick courses or tiling for tiling layouts
Tue, Aug 5, 2008 at 10:14:12 AM
Using the Fill Pattern as Tiling for Tile Layout, is it possible?
Sun, Feb 29, 2004 at 8:50:21 PM
Placing filled regions for tiling in bathrooms
Fri, Jun 10, 2005 at 10:35:11 AM
Tiling windows
Thu, Jan 30, 2014 at 2:20:42 PM
Tiling Seamless Texture Images
Tue, Oct 12, 2004 at 8:08:15 PM
Page generation time: 0.3557
