Forums >> Revit Building >> Technical Support >> Adding mullions to an existing window family
Thu, Aug 24, 2006 at 11:00:14 AM | Adding mullions to an existing window family
rskrynicki
I'm a residential designer, and I've been working with the default Revit windows etc for some time. However, now that it's come to detail work and using the family editor, I'm finding my work has slowed to a crawl. As of now, the one problem I can't seem to overcome is adding mullions to a window. I can do this with a set window size, but in a perfect world it'd be nice to be able to have mullions that would scale as the window changed size. Any help would be much appreciated. Thanks in advance.
Thu, Aug 24, 2006 at 5:22:43 PM | RE: Adding mullions to an existing window family
eldados
eldados Avatar
4.5 Stars: 8 Votes
i'm sure someone was asking this question a while ago Smile do a little search in the forum, but quickly: yes you can add mullions and yes you can even specify how many of them, i will suggest downloading a family with multiple mullions and check how it's built, if you can't find one, email me.
Integrator
KarelCAD
Adding mullions to a window
Wed, Dec 14, 2016 at 10:19:19 AM
Adding mullions to a fixed or casement window
Mon, Feb 27, 2006 at 1:52:13 PM
Window mullions as instance parameters...!
Thu, Jul 31, 2008 at 3:56:04 PM
Window Mullions
Wed, Nov 29, 2006 at 7:58:12 AM
Nested window mullions (Generic Models) don't appear in Window Schedule
Wed, Apr 30, 2008 at 11:33:20 AM
Page generation time: 1.1536
