Forums >> Revit Building >> Technical Support >> Missing Section Marks on Floor Plan
Thu, Aug 24, 2006 at 9:36:36 AM | Missing Section Marks on Floor Plan
JHanby
3.5 Stars: 3 Votes
For some reason my section lines/tags are not showing up on my floor plan. I have checked the visiblilty and the sections are checked to be shown. I have an AutoCAD drawing linked in the file and have it shut off for visibility. They show up on the second floor but not the main floor. What am I doing wrong? Any help would be appreciated.
Jill
Thu, Aug 24, 2006 at 5:19:26 PM | RE: Missing Section Marks on Floor Plan
Thread Post Kudo! #2
eldados
eldados Avatar
4.5 Stars: 8 Votes
check your drawing scale and make sure your sections are not set to be hidden if "scale coarser than..." if you hover over a section will it show up?
Integrator
KarelCAD
Fri, Aug 25, 2006 at 7:11:18 AM | RE:
JHanby
3.5 Stars: 3 Votes
Thanks!! That was it. I changed the scale from 1/8" to 1/16" so it would fit on the page. When I changed it back to 1/8' they showed up. I checked the "scale coarser than" and it was set to 1/8'. What is the purpose of this setting?
Jill
Fri, Aug 25, 2006 at 7:37:22 AM | RE: Missing Section Marks on Floor Plan
coreed
coreed Avatar
4 Stars: 16 Votes
the purpose of this setting is that at smaller scales the section lines/tags become quite large. Under certain circumstanes/scales you might not want to show these items. this setting allows you to do it globally throughout the project HTH Post edited on 2006-08-25 07:37:50
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Apr 24, 2010 at 6:11:08 PM | Missing Section Marks on Floor Plan
toolSHED1989
I am having a similar problem but it has not been solved by the "set scale coarser than" or moving the view range of the section through the floor view range.  It still isn't showing up in plan view.  Any ideas?
Sun, Apr 25, 2010 at 6:04:15 PM | Missing Section Marks on Floor Plan
mcantwell
mcantwell Avatar
Check phases
Are they hidden in the view - lightbulb at bottom of screen
Override category in view
Check that the height of the section cuts the cut plane of the horizontal view
One save for levels and sections that have wandered is to use a scope box to pull sections and levels into line.
Place a scope box around the building
Find a view where you can see the levels or section markers and assign the levels or sections to the scope box in their properties. Do a bunch at a time.
This will snap as many levels and scope boxes as you select into a known location
Mon, Apr 26, 2010 at 8:33:17 AM | Missing Section Marks on Floor Plan
If the sections were cut in a detail plan, they will not show in a floor plan.
Mon, Apr 26, 2010 at 9:01:14 AM | Missing Section Marks on Floor Plan
toolSHED1989
The sections were cut in floor plan because i can see the section in floors 1-7, but my 8th floor it did not show up and when I tried assigning floors to the scope box, my 8th floor was not an option for that.
Mon, Apr 26, 2010 at 9:56:25 AM | Missing Section Marks on Floor Plan
Is your level 8 really a level?
Obviously, your section does not cut through this "level".   So - how do you fix that?  Many ways but here is an easy one - In the section... drag the top of the section box up.
Mon, Apr 26, 2010 at 2:25:56 PM | Missing Section Marks on Floor Plan
toolSHED1989
Yes, my level 8 is a level.  There is a level tag in elevation for it and it does not deviate from any of the other 7 floors. And I have dragged my section view box up like 100' above where the floor should be and it still does not show up in plan.
Tue, Apr 27, 2010 at 12:22:46 PM | Missing Section Marks on Floor Plan
#11
How did you create your 8th level plan?
Tue, Apr 27, 2010 at 6:50:07 PM | Missing Section Marks on Floor Plan
#12
mcantwell
mcantwell Avatar
Can you upload somewhere so we could have a look?
Sun, May 2, 2010 at 5:05:52 PM | Missing Section Marks on Floor Plan
#13
toolSHED1989
Eh, It was for an architecture project that was already due and I found an end-around on it.  Thanks though.
Wed, Jan 2, 2013 at 4:13:20 PM | Missing Section Marks on Floor Plan
#14
ElyseJMB
I have had a similar issue with one of my projects. The foundation level doesnt show Building Section B but it shows Building Section A. The man and the upper floor show both A and B. Section B cuts far below the foundation slab.
I've been through all my setting and my views, nothing makes sence. Any Advice?
Thanks
Elyse
Wall section marks not showing in roof plan
Thu, Jun 10, 2010 at 2:08:07 PM
How to make section marks smaller?
Wed, May 9, 2007 at 4:47:08 PM
Room tags, floor marks etc. misplaced in the mirrored plan
Wed, Aug 29, 2018 at 2:37:35 PM
Section marks appearing on plans
Thu, Dec 6, 2012 at 4:26:26 AM
section marks
Tue, May 17, 2005 at 12:54:13 AM
Page generation time: 0.6230
