Forums >> Revit Structure >> Technical Support >> Revit Structure to StaadPro, can it work?????
Wed, Aug 23, 2006 at 9:32:14 PM | Revit Structure to StaadPro, can it work?????
Daggraa
Hi, I am now facing a problem on how to export DXF file to Staadpro for analysis?? Anyone got a solution. Thanks
Thu, Aug 24, 2006 at 9:40:28 PM | RE: Revit Structure to StaadPro, can it work?????
TomDorner
4.5 Stars: 25 Votes
To export a 3D DXF file, go to or create a 3D view with the categories visable that you want to export. Then go to File>Export>CAD Formats and choose your flavor of DXF export in the drop-down file type box. If you are using Revit structure then I'm not sure if there is an API out and back fromStaadpro. You may want to ask your reseller. HTH Tom
Inventor to Revit Structure 2010 or 2011
Fri, Dec 10, 2010 at 5:45:29 AM
Metalic Structure in Revit Architecture
Fri, Dec 3, 2010 at 1:10:10 PM
SketchUp into Revit Structure 2009
Fri, Feb 27, 2009 at 9:51:24 AM
Modyfing columns in Revit Structure
Thu, Nov 1, 2007 at 12:55:53 PM
Revit Building - Revit Structure Interoperationallity and worksets
Thu, Jun 21, 2007 at 10:50:08 AM
Page generation time: 5.4426
