Forums >> Revit Building >> Technical Support >> Multiple monitors
Mon, Oct 4, 2004 at 9:31:11 PM | Multiple monitors
liam
I am wandering if there is anyone out there using multiple monitors for the one project file. Is this possible, easy to use etc..? Any comments on the issue would be greatly appreciated. Thanks, Liam
Tue, Oct 5, 2004 at 12:51:14 AM | RE: Multiple monitors
ale02
ale02 Avatar
3 Stars: 3 Votes
I think you are talking about workset. It works something like Xref and it is suitable to work multiple PCs or workstations. You can check through the help files to see how it works & it is important to know the basic principles of workset especially central file and local file and how to save to central. Hope you find this helpful
Wed, Oct 27, 2004 at 4:08:15 PM | RE: Multiple monitors
Deasty
In reference to multiple MONITORS...yeahI use them on a daily basis....but I found that because you cannot drag a view window outside of the revit window it is of little to no advantage. All I use it for it for having multiple sessions of Revit open, or for other programs I'm running at the same time. Hope this helps. MD
Design is life displayed in a static medium. Deasty
Tue, Nov 20, 2007 at 8:53:21 PM | Multiple monitors
kprossick
 Yes, you can do this, but it takes a bit of outside the box thinking.
1) What you need to do is set the desktop to extend acroos all of the monitors you want to use.
2) Start revit Architecture. It will either appear in a single monitor or across all of the monitors combined.
3)  Make sure that Revit is set to be in a floating window (one that is not locked in place but can be moved).
4) Move the Revit Window so the top left corner of the window aligns with the top left corner of your furthest left monitor (top left monitor if you stack monitors vertically)
5) Drag the bottom right corner of the Revit window to align with the bottom right corner of your bottom-right most monitor.
6) When you open up views within a project, make them flowating windows, and you can move them around in any way you wish across all the monitors now.
7) Save these settings in Revit
For example. I currently use 3 Monitors. The Center is my main with 2 flanking monitors on either side. With Revit extended over all the monitors I use the left monitor for 3d Views of my model, the center monitor I use for the floor plans, and the right monitor for elevations and sections.
The only drawback is that the Design Bar and Menu Bar is on the far left side. The Project Browser can be moved however to where ever you want it. There might be a way to move the Design Bar, but it doesn't bother me where it is, so I haven't looked into it. The good part about Revit is there is more than 1 way to get to a command (ie Right Cliking) and if you take the time to conform to them, then this becomes a minor issue.
Unfortunately, it is not an automatic thing and takes time to learn how to set-up, but once you do, it works beautifully. Also, I personally believe that by Revit being set up like this, it offers a bit of personal flexibility.
If you have any questions, just reply and I will help as best as I can. Good Luck.
I htink I will make this solution a new thread.
Shine On You Crazy Diamonds,
Keith Prossick
Floating Windows 4 Multiple Monitors & wow putting CAD into sweeps is work.
Fri, Jul 14, 2006 at 4:58:12 PM
Two monitors
Wed, Apr 26, 2006 at 11:08:36 PM
Multiple Displays
Thu, Jul 21, 2005 at 11:50:41 PM
How to use Multiple Monitors with Revit
Thu, Feb 14, 2008 at 11:12:31 PM
two monitors?
Wed, May 3, 2006 at 7:30:53 PM
Page generation time: 1.3711
