Forums >> Revit Building >> Technical Support >> Parameter in a Detail Group
Wed, Aug 23, 2006 at 3:04:31 PM | Parameter in a Detail Group
BnR1
I would like to change a Parameter and have it change text within a Detail Group so I don't have to edit group and change everything each time. Is this possible?
Wed, Aug 23, 2006 at 5:50:03 PM | RE: Parameter in a Detail Group
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What do you mean "have to change everything each time"? If you have a detail group containing text, editing the group and changing the text and finishing the group then propagates the change to all instances of that group. How is this any different from say having a symbol for your text and a type parameter and changing this. If you were to go for this method you lose your ability to adjust the text box size easily without having to go edit the family each time. The first method to me seems like the easier option, unless i'm missing the point?
Tue, Aug 29, 2006 at 12:26:52 PM | RE: Parameter in a Detail Group
BnR1
I want to change the basement wall height and have it change the text in the project summary box, change it in the detail group of a typ wall section (just text here not a dim) and on the basment info list. I find I miss at lest one of these places. So how would be a good way to do this?
"group parameter under" changed upon loading into project
Wed, Aug 11, 2021 at 3:16:03 PM
Linked file model missing attached detail group
Mon, Aug 17, 2009 at 8:26:38 AM
Detail Group Partial Visibility
Fri, Jul 15, 2016 at 10:37:44 AM
Attached detail groups missing from model groups...
Mon, Aug 17, 2009 at 8:11:10 AM
Revit 2013: detail number parameter missing
Thu, May 2, 2013 at 7:47:19 AM
Page generation time: 1.7488
