19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> I have 2 questions for Sheet labels, please help
2 Posts No Rating |
First, when i create a sheet and load it into my project, the label text i enter does not wrap, it goes off the border when i enter project name etc.
how do i get the label text to wrap?
second is i am trying to create my own labels using shared parameters. when i create them in the sheet family editor, i canot click the "filter parameter" button as it says in the help menu. when i go into the project, i go to project settings and select the shared parameter label but i cannot set it to be a type, only as an instance and i need it to be a type.
how do i create a label in the sheet family editor to be a type.
thanks
In the family:
Simply adjust the wrapping points of the label parameter to have it wrap at the desired length. I always type example sample text to the maximum length in the family to ensure it wraps as i desire it to.
So you've created a shared parameter called "Filter"?
To use this in the project,
Go to settings-->Project Parameters-->Add-->Shared Parameter-->Select the parameter
Here you can now pick whether you want it to be a type or instance parameter.
If you want it to be a type parameter i tend to add it to project information as an instance parameter. Which is essentially a type parameter as only 1 project exists. If you wanted each sheet to be different you would tick Drawing Sheets instead of Project Information....
HTH.
2 Posts No Rating |
thanks i got it
Titleblock Labels (Custom to each sheet) [ 1 2 ] |
Mon, Oct 5, 2015 at 2:46:21 PM
22
Title Labels |
Sat, Jun 29, 2013 at 12:54:18 PM
14
Title Block Labels |
Wed, Feb 14, 2007 at 11:52:49 AM
Sheet List |
Mon, Jan 7, 2013 at 4:35:52 PM
Creating custom labels showing area in a titleblock. |
Wed, Aug 7, 2013 at 10:40:49 AM
