Forums >> Revit Building >> Technical Support >> Align Floors on Multiple sheets
Wed, Aug 23, 2006 at 10:20:38 AM | Align Floors on Multiple sheets
mtveerman
I see there are already 2 posts on this forum that ask this same question, but I can't figure out how the answers work. How do I align Floors on multiple sheets? How to make sure that the floors are on the same location on each sheet? A suggestion was made to add ref-lines to the family. I did and although I can't see these lines (they don't show up in the project sheets views), I can snap to them. But than, how to snap a viewport to the ref-lines? I can't get a snap on a viewport when I try to move, nor can I snap to building elements inside the viewport since the viewport is not active. How can I center a viewport on a sheet? Thanks!
Thu, Aug 24, 2006 at 5:40:46 PM | RE: Align Floors on Multiple sheets
eldados
eldados Avatar
4.5 Stars: 8 Votes
in short" you can't! you can add a line or an X to your title sheet family and try and move your plans to come close to it, it won't snap so you'll have to do it by eye.
Integrator
KarelCAD
Thu, Aug 24, 2006 at 5:49:11 PM | RE: Align Floors on Multiple sheets
jgmas
OR, INSTEAD OF DOING IT ON THE TEMPLATE TITLE SHEET YOU CAN DO THE SAME ON THE PROJECT'S TITLE SHEET DRAW A LINE ON THE FIRST SHEET ALIGN YOUR FLOOR TO THAT LINE (BY EYE) THEN COPY A PASTE (CURRENT VIEW) THE LINE ONTO THE NEXT SHEET AND ALIGN YOUR OTHER FLOOR TO THAT LINE, AND SO ON AND SO ON
Thu, Aug 24, 2006 at 6:02:33 PM | RE: Align Floors on Multiple sheets
eldados
eldados Avatar
4.5 Stars: 8 Votes
you still need to do it by eye, you can't snap but it will get close. i know they are talking about this feature in future release...
Integrator
KarelCAD
Fri, Aug 25, 2006 at 1:54:11 AM | RE: Align Floors on Multiple sheets
mtveerman
Well, now I see why I could find the answer to my question. Thanks for the replies, and hopefully they will integrate such a feature in future releases. Maarten
Tue, Sep 12, 2006 at 5:45:55 PM | RE: Align Floors on Multiple sheets
mabel
Thanks for the responses. I look forward to this feature too.
Wed, Nov 17, 2010 at 11:35:23 AM | Align Floors on Multiple sheets
lunchtrayrider
3.5 Stars: 7 Votes
I just tried this in 2011.  you can snap to grids in the plan view and use em to align to something on the sheet (a small tick or whatever).  i'm so pumped right now.
I like scooters. and motorcycles.
Wed, Nov 17, 2010 at 3:26:28 PM | Align Floors on Multiple sheets
lunchtrayrider
3.5 Stars: 7 Votes
lol, i'm still pumped.  now all my plans are aligned. perfectly.
Align Plan Viewports on Multiple Sheets?
Mon, Sep 24, 2007 at 6:57:36 AM
View alignment on Multiple Sheets
Thu, Aug 27, 2009 at 2:12:19 PM
Engineering Stamps on Multiple Sheets
Wed, Apr 8, 2015 at 11:13:44 AM
Spread a schedule over multiple sheets - Issues
Mon, Aug 29, 2022 at 6:32:10 AM
Same View on Multiple Sheets
Sun, Aug 28, 2005 at 5:51:36 PM
Page generation time: 2.3076
