7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> SPLIT REGIONS
21 Posts No Rating |
Instead of using the subregion tool, I have been using the Split region tool to split between the road, curb, and grass. The only problem is that when i move the curb region up about 6" there is an open gap between the road and the curb. Is there any way to create a loft between these two region to represent the curb better, or is there a better way to do this in general.
The short answer is no. Doing site work in Revit is very difficult and generally I avoid it except for context to be used in a rendering. Then I try to keep things very flat or with a regular slope.
For your situation you might try some of the curb site components which will follow gentle splopes but even then not perfect. I have also used walls with edited profiles or attached to reference planes to act as curbs.
A search of this site or out at www.augi.com may yield more indepth methods other use.
HTH
Tom
I know this post is old - but with the new Revit versions, try this: http://bimtionary.blogspot.com/2010/02/curb-and-gutter-along-topo.html
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
Scheduling cut and fill when using split regions |
Sun, Sep 21, 2008 at 8:56:58 AM
Splitting wall Regions |
Tue, Jan 27, 2009 at 10:16:18 AM
Walls, Split regions and Materials |
Fri, Jan 20, 2006 at 3:13:12 PM
Graded Region from split surfaces |
Fri, Feb 1, 2013 at 8:36:27 AM
editing split face boundaries |
Wed, Jun 4, 2008 at 9:43:18 AM
12
