11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Site-contour
Wed, Aug 23, 2006 at 5:57:17 AM | Site-contour
Bhawani
Hi, when contour are imported from autocad to revit ,after all the proceedure is done like use imported,the site is created, but the contour lines & pts of revit doesn't match with the autocad dwg & also the boundary of contour in autocad.there is no point in just getting the toposurface or site in revit without exact values.This is serious problem.Can any one help immidiately.Waiting for the reply. Thank u.
Linking AutoCAD Site Contour missing 2014
Wed, May 27, 2015 at 7:56:32 AM
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Revit Linked File Question: UNABLE to unhide linked contour in Site plan window
Tue, Jul 10, 2012 at 3:42:09 PM
Contour Lines - not a surface
Wed, Mar 31, 2010 at 2:11:21 PM
Contour line intervals at different scales
Thu, May 3, 2007 at 11:16:59 AM
Page generation time: 0.1405
