22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> exporting to AutoCad
Is there a way to purge AutoCad files while exporting to AutoCad from Revit.
Looks like I'll have to open all the dwg files and purge them individually otherwise.
Randy
you can purge the revit drawings befor you export and under the options tick merge overlapping lines...
that's all you can do AFAIK
Where is "merge overlapping lines" option when exporting to CAD? i'm using 2013
From you HELP
When you export a 2D view to a DWG file, lines are treated as follows:
- If 2 lines overlap in the drawing, the thicker of the lines is retained. The thinner line is shortened or removed.
- If a thick line is shorter than a thin line and its start point and endpoint fall within the thin line, no action occurs.
- If 2 collinear lines with the same visual parameters overlap, they are merged into one.
- When walls become lines in the DWG file, no short collinear lines are produced
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2171-Print_Ex2171/2172-Export2172/2173-Exportin2173/2175-Exportin2175
Trouble w/ exporting to AutoCad |
Thu, Jan 20, 2011 at 11:18:07 AM
Exporting Layouts in to AutoCAD / piping issue... |
Thu, Sep 4, 2008 at 4:12:10 PM
exporting to autocad |
Fri, Aug 31, 2012 at 7:35:41 AM
Tue, Jan 30, 2007 at 11:32:22 AM
Exporting into AutoCad via e-mail |
Sat, Oct 2, 2004 at 12:44:57 AM
