Forums >> General Discussion >> Wishlist >> Break Grid lines
Mon, Aug 21, 2006 at 2:12:05 AM | Break Grid lines
JoeM
It would help greatly if one could break the grid lines similar to the sections line. We have several projects with U shaped builings where being able to not show the grid lines in the middle courtyard would be helpful.
Mon, Aug 21, 2006 at 4:08:43 AM | RE: Break Grid lines
jfurlong
i agree i can see when that would be usefull hope this helps my workaround is to creat 2 grid lines. align them, lock them, then rename them with sililar names like "a" and "A" or "1" and "1."
Tue, Aug 29, 2006 at 9:37:42 AM | RE: Break Grid lines
glenriv
It would also be usefull in elevation views .. Mening not showing the axis going though the building
Mon, Oct 30, 2006 at 9:55:31 AM | Break Grid lines
glenriv
Well i figured something out myself but is not perfect....I basicly just create myself a second grid patten but this time the color is white and it has no symboles. Then i trace over the line i want to hide with my BLANK grid line and it hides it in plan an elevation. It s a satisfaying result but not perfect, as it s a white line it will hide everything that s underneath. So you might have a thin white line crossing your walls where there use to be a grid line.
Mon, Dec 18, 2006 at 1:28:16 AM | Break Grid lines
Profoxcg
Profoxcg Avatar
I agree !!
"No one said it would be easy..."2006 Labrador Black Lancer Evolution IX Dell Precision Workstation 490 WoodCrest - 4 Cores !!Revit Building 9.1 + Sketchup + 3dsmax 9 + M~RCurrenlty playing Zelda:Twilight Princess + FFXII + MGS3
Thu, Jan 24, 2008 at 11:44:48 AM | Break Grid lines
rascal
Hear, hear!  Would be infinitely useful; how did this feature get omitted in the first place, seems pretty intuitive to have included it?!
-r
Tue, Mar 3, 2009 at 1:43:42 PM | Break Grid lines
bluebke
some of you may have already discovered this, but it seems this has been fixed (sort of) in 2009.  Click on a grid line, go to properties, click Edit/New, and under the "Center Segment" parameter, pick None.  Each line then appears with blue grip dots you can adjust.  You may want to duplicate the type first if you want continuous grids also.
Wed, Mar 4, 2009 at 6:20:32 AM | Break Grid lines
KingRevit
4 Stars: 12 Votes
cool, never saw that one coming in. if now it was a instance rather than type parameter, or even still instance and type.
Wed, Mar 4, 2009 at 8:22:36 AM | Break Grid lines
tim123
4 Stars: 19 Votes
You can duplicate it and have one type as being continuous and the other as broken.
Fri, Jul 16, 2010 at 8:07:16 PM | Break Grid lines
naddlles
Regarding the breakline "center"  I see it broken in my elevations, but the bottom portion of the grid is still showing, and my crop region wont cut it out as it's an annotation.  Is there any way to hide the botton part of the grid and only show the top without affecting the grids on plan?
 Thanks!
Sun, Jul 18, 2010 at 9:36:15 AM | Break Grid lines
#11
You can adjust the length of grids in any view without affecting other views - just click on the grid - then click on the 3D switch to change to 2D.  (You will see the 3D somewhere near your grid)
Detail/ Break lines
Mon, Apr 29, 2013 at 4:02:35 PM
View Breaks and break lines
Tue, Jun 26, 2012 at 6:49:55 PM
Break lines sizes.
Mon, Mar 2, 2009 at 2:15:32 PM
Stair Elevation with break lines
Tue, Mar 23, 2010 at 2:19:30 PM
Showing break lines with Ramps and Stairs
Mon, Jul 30, 2018 at 11:02:36 AM
Page generation time: 0.7044
