Forums >> Revit Building >> Technical Support >> shaped opening on curved wall.
Mon, Aug 21, 2006 at 1:48:39 AM | shaped opening on curved wall.
mmetin
mmetin Avatar
is there a way to cut curved walls by a shaped opening (triangular or curvy linear).. edit profile works on straight walls but not in curved ones.
Mon, Aug 21, 2006 at 5:26:17 PM | RE: shaped opening on curved wall.
eldados
eldados Avatar
4.5 Stars: 8 Votes
DO YOU MEAN LIKE THIS? Smile all you need to do is draw a reference line in plan, infront of you wall, set the work plane to the reference plane yo have drawn (top left button it's called "Plane"Winking it will ask you what view to open, if you have a section line infront looking at your wall in elevations, pick it. create a void family, draw your shape and make sure you cut the geometry off the wall when you finish Smile HTH Post edited on 2006-08-21 17:29:51
Integrator
KarelCAD
Tue, Aug 22, 2006 at 12:40:25 AM | RE: shaped opening on curved wall.
mmetin
mmetin Avatar
thank you..it worked.
Wed, Aug 23, 2006 at 9:19:03 AM | RE: shaped opening on curved wall.
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
thank you mr. eldados I also needed to know this
Wed, Aug 23, 2006 at 9:40:07 AM | RE: shaped opening on curved wall.
Aubrey
mmetin, For some shapes you may want to create a void blend so the opening flares to follow the arc. Play and have fun! This is one of the most useful tips I ever stole from this site. ;>Winking Yours, Aubrey
Thu, Jun 28, 2007 at 4:58:54 AM | shaped opening on curved wall.
valkanov2001
Thank you a lot. Really useful
Tue, Feb 5, 2008 at 9:54:36 AM | shaped opening on curved wall.
mmonti
Eldados, thank you very much for this explanation because it answered how to do this to many people but I'm a bit new as a revit user and I couldn't understand Puh I think people like me need more attached drawings of the process (some kind of tutorial) to really understand. If you have the time to do that it would be of so much help to more of us.
Thanks,
Thu, Sep 30, 2010 at 6:24:08 AM | shaped opening on curved wall.
iluzek
Hi there. I'm new to the revit and i'm in college atm doing it. I'm eager to learn more and i'm interested in doing what was described in this thread however i find myself a bit too fresh in revit to grasp how to do it...Not to mention that my teacher seem to be freesher than myself. Would really apriciate if someone could make a video or descibe it in step by step for me. Thanks in advance -  my msn : krzysztofgoszka1@tlen.pl
Nothing is impossible.
but
Nothing is ever easy.
Fri, Jun 3, 2011 at 12:30:14 AM | shaped opening on curved wall.
ubi1
I can't make a recess in the wall to be curved the same as the original wall.what i did in the attached photo, is a Family , void object cut in the wall to form arched opening,but the result is what you see , any ideas
Sun, Nov 6, 2011 at 1:52:50 PM | shaped opening on curved wall.
jodyb166
I am trying to create a curved glass wall 1' thick, with circular openings for wine bottles. Is there any way to create the voids in the curved wall for the bottles?
opening in slanted curved wall
Mon, Sep 29, 2008 at 10:32:57 AM
Arched Opening in a Curved Wall [ 1 2 ]
Mon, May 5, 2014 at 7:16:28 AM
18
Curved Wall
Sun, Nov 13, 2011 at 4:56:42 AM
How To Fill A Curved Wall Opening? [ 1 2 ]
Fri, Sep 14, 2012 at 10:25:00 AM
15
Introduction / wall irregular shaped opening
Wed, Mar 26, 2014 at 6:57:30 AM
Page generation time: 1.2715
