Forums >> Revit Building >> Technical Support >> PROBLEMS WITH DOWNLOADIING from revit city
Sat, Aug 19, 2006 at 8:17:24 AM | PROBLEMS WITH DOWNLOADIING from revit city
robert
g'day, i am still having probs with downloading from revit city i am using mozilla firefox. my settings are: tools>options>save all files to desktop when i select download, the "download completed" very quickly appears without ever seeing any "progress bar" in action the file can not be found. so for i have not seen any filenames on items of interrest to me therefore it is not possible to do a proper search i do not have any trouble receiving files some month ago nor with files from other sources which were automaticly downloaded. could someone throw some light on the matter please? thanks, robert. Post edited on 2006-08-19 08:32:45
Mon, Aug 21, 2006 at 10:17:06 AM | RE: PROBLEMS WITH DOWNLOADIING from revit city
ArchWestCY
4.5 Stars: 7 Votes
I use Firefox, and I had to figure this one out already. When you get to the screen that says this: ************************************ "Thank you for downloading from Revitcity.com Please remember that your download was only possible by the generosity of others. Please give back by uploading your families today! If your download does not begin in 15 seconds, Click Here to download. If your browser is opening the file up as a text file, right click the link and select "Save Target As" (or similarily worded). Upload Families" ************************************* Right click on the link in the middle that says "Click Here" then pick "Save Target As", and it should download right away. Just like it says in the last line. ArchWestCY
Mon, Aug 21, 2006 at 8:20:50 PM | RE: PROBLEMS WITH DOWNLOADIING from revit city
robert
ArchWest CY thanhs for your responce mate. just prior to your responce, a mate of mine had an other solution which works well. try this: after selecting the "download" the screen comes up which tells you to "click here" select the "click here: with a RIGHT HAND click then select "Save Llink As" bingo! , the standard "save" dialog box comes up and you can select your favoured folder. the file is actually saved in the correct rfa format. thank so much for your help cya, robert.
Tue, Aug 22, 2006 at 3:43:07 PM | RE: PROBLEMS WITH DOWNLOADIING from revit city
ArchWestCY
4.5 Stars: 7 Votes
Right. I think that's what I said. It is a bit strange to do it that way, but it always works for me. Happy downloading ArchWestCY
Fri, Nov 16, 2007 at 11:22:53 AM | PROBLEMS WITH DOWNLOADIING from revit city
asanders
I've been trying to download families using the method suggested above on Firefox... while it seemed to work initially, I have recently been recieving .php files instead of .rfa files.
I switched to Explorer, and the downloads now work exactly as intended.
Hopefully RevitCity can fix this Firefox problem, so that Firefox users like myself don't have to taint our machines with Explorer just to download from this site.
Fri, Nov 16, 2007 at 11:39:53 AM | PROBLEMS WITH DOWNLOADIING from revit city
You are doing something wrong.  I use Mozilla firefox and my downloads work just fine using the save as.  Just right click on the click here and use save as.
Downloading Components from Revit City Problems
Mon, Sep 11, 2006 at 9:51:50 AM
Uploading Revit Content to Revit City
Mon, Apr 16, 2012 at 7:00:19 AM
Revit City Newbie
Sun, Apr 17, 2011 at 8:13:15 PM
Revit City DVD
Sat, Jul 29, 2006 at 7:16:44 PM
Long Beach City College Revit [ 1 2 ]
Thu, Jan 7, 2010 at 6:08:25 PM
20
Page generation time: 3.6920
