Forums >> Revit Building >> Technical Support >> Elaveation / Section Lineweights by depth. screening by distance.
Fri, Aug 18, 2006 at 10:37:59 AM | Elaveation / Section Lineweights by depth. screening by distance.
jfurlong
please have a look at this and let me know what you think. i aproach the section/elevation linweight for dept option differently than using the line work (altough i still use it at times.) i have attaced a pdf with a small tutorail on how i do it. there are 2 small problems with the way i do it. (basically using multible section) but i'v sent them to autodesk in a wish list to be fixed. i would appriciate your thoughts on this as i know its a big problem for a lot of people and the tool that we are all looking for (screening by distance) is not in 9.1 or is not in development fo version 10 or so im lead to believe.
Fri, Aug 18, 2006 at 10:39:34 AM | RE: Elaveation / Section Lineweights by depth. screening by distance.
jfurlong
and the file i used in the pdf
Importing AutoCAD Linetype Screening Values into Revit
Fri, Jul 27, 2007 at 12:53:09 PM
Section view depth
Tue, Jul 15, 2014 at 8:29:07 AM
Depth perception in Elevation
Mon, May 5, 2008 at 9:30:15 AM
Screening
Sat, Mar 5, 2005 at 1:26:18 PM
Elevation lineweight in regards to depth
Fri, Aug 18, 2006 at 10:35:40 AM
Page generation time: 1.3805
