22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Linework and Elevations
7 Posts No Rating |
what is the best way to edit elevations so that they read like proper architectural drawings? As of now, if I apply a linweight to a line in elevation, it is applied to the entire line, even if it is partially hidden in that elevation, so i have to make it an invisible line first and then draw a detail line where the original line was. Is there a faster, easier way?
1 Posts No Rating |
"what is the best way to edit elevations so that they read like proper architectural drawings? As of now, if I apply a linweight to a line in elevation, it is applied to the entire line, even if it is partially hidden in that elevation, so i have to make it an invisible line first and then draw a detail line where the original line was. Is there a faster, easier way?"
When you applied a thicker lineweight, you see two dots on both end of the line, you can actually drag those dots to where you want the line to end.
Improving Linework in Sections & Elevations |
Sun, Mar 30, 2008 at 12:30:48 AM
Can you save linework? |
Tue, Aug 12, 2008 at 7:37:07 PM
Linework tool issue |
Mon, Sep 26, 2011 at 3:20:44 PM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Within Revit Linework |
Mon, Jun 23, 2008 at 4:16:05 PM
