Forums >> Revit Building >> Technical Support >> newbie help with titleblock
Thu, Aug 17, 2006 at 8:03:55 PM | newbie help with titleblock
stritch
I am brand new to Revit and am having a dense moment. All I want to do is create an editable text field in my titleblock. But I find that when insert the titleblock into a drawing I can not edit text. So I tried using labels, but I can not get them to display sample text of my own choosing. How do I create a new label to my own specifications OR how do I create a plain editble text field?
Thu, Aug 17, 2006 at 11:00:45 PM | RE: newbie help with titleblock
puzzle
4 Stars: 10 Votes
Have you tried the tutorial? If the labels are not displaying what you what just change them after you have load it into your project. Go to Settings<Project Information.
Macca
Sunshine Coast
QLD Australia
Fri, Aug 18, 2006 at 12:42:36 AM | RE: newbie help with titleblock
stritch
I am not happy with the default text and I want to be able to have my own titles. I tried changing the Sample Text but that didn't do anything useful. for example what I want is if I have non-editable text "Drawn:" I want to follow it with editable text "###" rather than "Author".
Fri, Aug 18, 2006 at 1:28:29 AM | RE: newbie help with titleblock
puzzle
4 Stars: 10 Votes
When you add the parameter to the editable text down the bottom there is an box with example text, put in what you need there. Drawn by & Checked by will only come in with this text. Post edited on 2006-08-18 01:31:56
Macca
Sunshine Coast
QLD Australia
Fri, Aug 18, 2006 at 1:55:29 AM | RE: newbie help with titleblock
stritch
nope, didn't work. I am using 8.1 if that matters.
Fri, Aug 18, 2006 at 3:24:21 AM | RE: newbie help with titleblock
puzzle
4 Stars: 10 Votes
sorry, those 2 will only cme in with author or checked by
Macca
Sunshine Coast
QLD Australia
Sun, Aug 20, 2006 at 5:44:21 PM | RE: newbie help with titleblock
stritch
So is there any way to have editable text that comes in with sample text of my own choosing?
Sun, Aug 20, 2006 at 9:07:13 PM | RE: newbie help with titleblock
timOthyj
4.5 Stars: 14 Votes
open the title block in a new drawing and set the type you want and design and the save it as your main titleblock. Be sure to change the name to something different... Example of titleblock editing... Post edited on 2006-08-20 21:17:41 Post edited on 2006-08-20 21:18:05 Post edited on 2006-08-20 21:18:21
Tue, Aug 22, 2006 at 9:21:59 PM | RE:
stritch
I must be having a dense week but how do I:
Quoting timOthyj - 2006-08-20 21:07:13
"open the title block in a new drawing and set the type you want and design and the save it as your main titleblock."
in particular how do I save it as my main titleblock? Are you saying that once I do this I can insert it as a normal titleblock? Can I then delete the old titleblock?
Wed, Aug 23, 2006 at 8:11:13 AM | RE: newbie help with titleblock
Elmo
3.5 Stars: 4 Votes
If you create a new parameter in a titlblock you need to make it a shared parameter and assign that shared parameter into your project in order for you to edit it there.
Titleblock resized after export
Fri, Feb 7, 2014 at 8:40:39 AM
Getting Titleblock in centre of page
Tue, Mar 30, 2010 at 7:13:05 AM
Titleblock question
Thu, Jul 2, 2009 at 4:23:14 PM
Titleblock Parameters
Tue, Apr 19, 2005 at 11:55:06 AM
Titleblock parameters / labels
Tue, Apr 7, 2009 at 12:41:34 PM
Page generation time: 1.7886
