Forums >> Revit Building >> Technical Support >> 90degree wall join
Wed, Aug 16, 2006 at 10:11:16 PM | 90degree wall join
A5Len
I have encountered a problem with a simple 90 degree wall join. Previously it had mitred perfectly but suddenly the two walls no longer join at all. The walls are set to allow join and are identical to each other. Anyone know why this would happen and how to fix it? I have even tried drawing new walls in this position Thanks
Wed, Aug 16, 2006 at 10:24:18 PM | RE: 90degree wall join
eldados
eldados Avatar
4.5 Stars: 8 Votes
...and what happens when you use the join wall tool?
Integrator
KarelCAD
Wed, Aug 16, 2006 at 10:44:52 PM | RE: 90degree wall join
A5Len
I assume you are talking about the 'edit wall joins' option? If so it does not recognise the walls as joining and thus will not allow you to choose that option
Wed, Aug 16, 2006 at 10:47:42 PM | RE: 90degree wall join
eldados
eldados Avatar
4.5 Stars: 8 Votes
can you send me a quick pdf so i can see what you are talking about... Smile
Integrator
KarelCAD
Wed, Aug 16, 2006 at 10:52:26 PM | RE: 90degree wall join
A5Len
This is how the wall finishes after using the wall command at the corner, with the chain option ticked on
Wed, Aug 16, 2006 at 10:55:11 PM | RE: 90degree wall join
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes i have seen it before... can you drag the walls away from each other, make sure that allow join is on both, make sure your walls have the same height and trim them. have you also tried to drag the blue dot (when you pick on a wall)?
Integrator
KarelCAD
Wed, Aug 16, 2006 at 11:02:52 PM | RE: 90degree wall join
A5Len
Yeah, I've tried all those options. This one has really got me stumped as i can't find anything that should cause this. Applies only to this joint on this floor
Thu, Aug 17, 2006 at 4:30:58 AM | RE: 90degree wall join
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Without looking at your file... Would one of your walls have an edited profile? If so, either remove the edit profile or edit it and make sure the sketch line where the wall join is to occur aligns with the reference plane of the wall. HTH.
Thu, Aug 17, 2006 at 11:37:35 AM | RE: 90degree wall join
dduarte
dduarte Avatar
3 Stars: 2 Votes
We've seen this before. Select one of the walls and right click on the blue dot at their intersection. Disallow join and then allow join. Toggling this sometimes solves the problem.
Thu, Aug 17, 2006 at 11:04:49 PM | RE: 90degree wall join
A5Len
Unfortunately, the walls are normal - no profile has been edited - and the toggling of the allow/disallow wall join option doesn't help
Sun, Aug 20, 2006 at 9:08:54 PM | RE: 90degree wall join
#11
A5Len
After many different attempts I have discovered the source of the problem. Somehow a room separation line was in the same plane as the wall and there was a conflict. wall separation line was switched off so wasn't seen.
Clean wall join
Sat, Apr 20, 2013 at 3:30:48 AM
11
Wall join options
Wed, Mar 23, 2011 at 7:46:49 PM
WALL JOIN PROBLEM - Ends showing in 3D and Elevation View
Tue, Jul 22, 2008 at 9:38:24 AM
Brick arch family coming in at 90degree to correct alignment
Tue, Mar 12, 2013 at 7:41:21 AM
Wall Join Options Disappear [ 1 2 ]
Tue, Apr 23, 2013 at 3:45:22 PM
26
Page generation time: 1.9835
