Forums >> Revit Building >> Technical Support >> Room Tags Filtered?
Tue, Aug 15, 2006 at 9:06:27 AM | Room Tags Filtered?
messinger
Is there a way to have a room tag that will stay visible with a label inside it that can be turned on or off in one click? I am trying to make rooms with tags that include people's names, but I need to be able to hide the people's name for certain meetings. Thanks
Tue, Aug 15, 2006 at 11:22:48 AM | RE: Room Tags Filtered?
dduarte
dduarte Avatar
3 Stars: 2 Votes
You can use object styles or the Yes/No parameter. http://revitbeginners.blogspot.com/2006/03/family-visibility-control.html
Tue, Aug 15, 2006 at 5:44:59 PM | RE: Room Tags Filtered?
messinger
Senor Duarte, Your advice was excellent. Your blog/ website is intriguing and informative and I will certainly continue to visit as I have questions. I will also reccomend it to others in need of solid advice. http://revitbeginners.blogspot.com/2006/03/family-visibility-control.html Thank you. To follow up: Every aspect of your suggestion from "Yes/ No Parameters" worked until the very end. After creating the yes/ no parameter, creating two distinct family types, and checking one and unchecking the other... the object (in this case the object was a label text called "Doctor Name"Winking did not turn gray. I loaded it into the project anyway and it showed up as a question mark, except it was not a text editable label (like a room name would be). Can you put the icing on this one? Is it a shared parameters issues? Thank you, Stephen
Tue, Aug 15, 2006 at 6:21:29 PM | RE: Room Tags Filtered?
dduarte
dduarte Avatar
3 Stars: 2 Votes
Works for me. See attached.
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:12 PM
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Vanishing room tags
Tue, Sep 6, 2005 at 5:54:21 PM
Page generation time: 1.0054
