Forums >> Revit Building >> Technical Support >> Elevation lineweight in regards to depth
Mon, Aug 14, 2006 at 11:40:31 AM | Elevation lineweight in regards to depth
fefifophil
I need to have my elevations of a house, have lineweights that are grey when the objects are a certain distance behind my elevation lines. I know how to turn off the far clip and I am using that. An example would be if you were drawing the elevation by hand and there was a dormer in the backround you wanted to greyed out because it did touch front or main part of the drawing. I would very much appreciate any help on this topic Philip
Wed, Aug 16, 2006 at 11:20:15 AM | RE: Elevation lineweight in regards to depth
jfurlong
use the "linework" tool its really the only option.
Wed, Aug 16, 2006 at 11:57:04 AM | RE: Elevation lineweight in regards to depth
For distant objects, I set my elevation depth deep enough to see the objects, then I trace them with the appropriate lineweight and then reset the depth so the elements don't show, just my light lines.
Fri, Aug 18, 2006 at 10:35:40 AM | RE: Elevation lineweight in regards to depth
jfurlong
i aproach the section/elevation linweight for dept option differently than using the line work (altough i still use it at times.) i have attaced a pdf with a small tutorail on how i do it. there are 2 small problems with the way i do it. (basically using multible section) but i'v sent them to autodesk in a wish list to be fixed. i would appriciate your thoughts on this as i know its a big problem for a lot of people and the tool that we are all looking for (screening by distance) is not in 9.1 or is not in development fo version 10 or so im lead to believe.
Sun, Aug 20, 2006 at 3:50:01 AM | RE:
daymissing
my MSN ID is daymissing_007@163.com i'm an studentl from an collage in china. can you help me about revit ?
Sun, Aug 20, 2006 at 4:57:13 AM | RE:
daymissing
my Skype ID is daymissing_007@163.com i'm an studentl from an collage in china. can you help me about revit
Lineweight Tool Overlap
Thu, Aug 7, 2008 at 9:25:16 AM
Depth perception in Elevation
Mon, May 5, 2008 at 9:30:15 AM
Interior Elevation linewieghts
Wed, Aug 19, 2009 at 2:02:43 PM
depth of view
Mon, Nov 21, 2005 at 9:46:00 AM
Lineweight on Surface Patterns?
Mon, Jun 15, 2009 at 11:54:52 AM
Page generation time: 1.4239
